Page 1 of 3
Spring Went Flying!!
Posted: Sun Nov 16, 2014 3:40 pm
by grant81rs
Gidday,
Today while fiddling about with the 78RS and a few electrical gremlins, I pulled apart the right hand control switch on the handlebars, (Indicators, starter, off/on/off) and yes the small spring and a tiny ball bearing flew out across the shed and never to be seen again...
Does any have any pictures, diagrams, info and or spares
as I am at a loss as to where they go!!, I mean I sort of know where they go as the off/on/off switch on now a little sloppy but I'm not to sure how they go in there.
Many thanks once again
Re: Spring Went Flying!!
Posted: Sun Nov 16, 2014 3:51 pm
by dwerbil
Shotgun pellets. I forget what size. Lost a bead on the left side but not the spring. Pain in the rear to deal with.
Posted: Sun Nov 16, 2014 3:55 pm
by dwerbil
With a spring and ball involved, there should be a tiny hole in the swith where the spring goes in first. The ball is last, protruding out a bit. The stiff little spring and ball works in conjunction with a partner ridge to keep the switch in its place. Or something like that.
Posted: Sun Nov 16, 2014 4:18 pm
by grant81rs
Gidday
Hey fellas, many thanks indeed, I looked at the hole in the red switch
and thought this has it be where it goes and must has something to do with it, I will start looking about for some things to get it working again.
Chat soon
Posted: Sun Nov 16, 2014 5:41 pm
by jagarra
Sometimes you can luck out and it's the same size as the spring in a retractable ball point pen. Cut to fit in length.
Posted: Sun Nov 16, 2014 5:42 pm
by dougie
Maybe the spring from a click-type ball point pen.
Posted: Sun Nov 16, 2014 5:56 pm
by dwerbil
This spring is at least half the size and much stiffer than from a ball point pen. Nice try.
Posted: Sun Nov 16, 2014 8:47 pm
by PAS
Kind of late but I have read that having them in a plastic bag as you disassemble is a good idea.
Posted: Mon Nov 17, 2014 1:32 am
by r75bitsa
Or maybe the same size as the one in a Bic lighter.
Posted: Mon Nov 17, 2014 1:34 am
by r75bitsa
I feel your pain mate, will be trying the old magnetised tip of a screwdriver to slot the ball into approx the right spot. Will pass on the news.
