It had been fully restored and is in lovely condition having covered a genuine 55,000 miles.
I have sorted all the brakes, flushed the tank and stripped the carbs , cleaning all jets etc.
The bike starts readily now and seems to run quite nicely but has not been out on the road yet.
I have noticed that when the bike is started and allowed to run for a few minutes a "light tapping noise" from somewher on the right hand side of the engine becomes apparent and when i knock the engine off i get a hissing sound from the right hand side valve cover.
Thinking this hissing may have been trapped water from the bike being washed i was not overly concerened but the bike is bone dry now and it still does it.
After doing searches and also finding an airhead on youtube with exactly the same symptoms i am coming to the conclusion that my crankcase breather valve may be kerfurkled causing the noise and excess crankcase pressure. This would not surprise me with the bike standing for so long.
I will strip the top end of the bike down to have a look but does this sound like i may be correct / likely and in addition am i likely to have the old type valve fitted on my year bike? Motorworks list the new reed valve at £24 so i will fit that.
Is there any way of checking the old valve for malfunction and what is the best way of removing it.
Anything else i should be aware of?
Many thanks Darryl
