Those butterfly shaft screws...
dougie
Post by dougie »
I have heard of various methods of securing them.
Backing them up on something solid, peen them with a pointed punch.
Or slot the end and hit them with a tapered punch.
It all sounds risky to me. One slip and it gets expensive.
I am considering just making them good-'n'-snug and using RED Loctite.
What do you folks think?
Re: Those butterfly shaft screws...
New screws done up tightly don't seem to give much trouble.
A pita when a screw head is damaged so new ones each time is the way to go (for me)
dougie
Post by dougie »
ME 109 wrote:New screws done up tightly don't seem to give much trouble.
Thanks Jeff.
I bought new screws. Six of them. (I know myself that well)
moore84rs
Post by moore84rs »
If you use Red Loctite; I suggest you apply a small amount to
the last few threads in the shaft, opposite the head.
To remove them you will need to heat the end with the Loctite above 400 degrees.
You want to heat the head as little as possible. If you heat it to the annealing
point of the brass the slot will be even easier to strip out.
Post by Garnet »
I have only had the butterfly srews out once, but them came out easily. After replaceing them I just gave them a light tap with a punch and they have stayed put.
The shaft and screws are brass and it takes very little effort to put enough of a mark on them to keep the screws in place.
dougie
Post by dougie »
moore84rs wrote:If you use Red Loctite; I suggest you apply a small amount to
Good point about the annealing. Thanks, I didn't think of that.
I am going to use Loctite 243 instead.
dougie
Post by dougie »
Garnet wrote:I have only had the butterfly srews out once, but them came out easily. After replaceing them I just gave them a light tap with a punch and they have stayed put.
Both the old and the new screws I have, are not brass. They stick to a magnet.
Post by Garnet »
Maybe it's my brain that is brass. :?
George Ryals
Post by George Ryals »
There is nothing on an airhead that needs RED loctite...including carb butterfly screws. Just snug the screws down and give them a little ding with a center punch. Of course support the shaft while doing the ding.
Smile it's contagious!
'85 R80RT wreck for parts
dougie
Post by dougie »
George Ryals wrote:There is nothing on an airhead that needs RED loctite...
How about you '69 BSA? ;)
