When I compress them off the motorcycle, and they spring back, it sounds like the fluid is cavitating.
I have one of the forks apart, I have not taken either end off of the damper rod.
My Haynes manual says the damper rod must be removed from the lower end of the stanchion. For me, it slid right out of the top, if I Invert the stanchion and remove the end cap and spring. Is that normal?
The rubber/nylon bumper at the very bottom of the fork slider crumbled in my hand. I did not find any type of nylon bushing which should be between the damper rod and the stanchion. Could this have crumbled away? It is item 7 in the image below. Could that be why I hear spring sounds when I compress them?
I also do not have number 10 from the image. The part is listed at Max BMW shown below. Since it is metal, I am assuming it was never present.
I have seen a few rebuild kits and they seem very straight forward. I don't think I will take apart the damper rod. The ball check value works. I am hoping I can clean any bits out of it with compressed air.
Any other advice?
