Fuel injection
Jeff in W.C.
Re: Fuel injection
Post by Jeff in W.C. »
chasbmw wrote:Back in the day people used to fit 40mm Bings to oil head GSs, usually done by travellers who wanted the simplicity of carbs.
Looking at some RTW travellers tales, the main failure that people seem to have is fuel pump problems, when the filters get blocked, as I understand it on the 800 BMWs, the fuel filter is intregal to the pump and are only supplied as a single unit!
That's progress for you.
Or the voltage regulator being part of the alternator. Yep. That's progress for you. Not quite fuel related, but similar to the above post.
Jeff in W.C.
1988 R100 RT
2018 R1200 GS
Re: Fuel injection
And the diode board/rectifier becoming a part of the alternator.
