LED spot light.
PITAPan
Re: LED spot light.
Post by PITAPan »
Sibbo wrote:I made up a couple of brackets for my spot lights yesterday. I oxy acetylene brazed them... a great way to fabricate small bits of metal if you don't own a MIG and I don't .
A photo of the two mounted .
and a single shot from underneath .
The lights have a really neat fine adjustment under the housing for setting the angle to the road . All the new black paint and the new LED housings kind of shows up the crappy condition of the headlight housing .... here we go !
I'll get around to wiring in the relay and switch next week when I get a bit of "unassigned'' time. Then I'll show a photo of the light spread .
Very nice work!. How did you do the elliptical cuts tightly enough to braze?
I want to do some mirror extenders and I need to join 2 flat plates to a tube, and each of the plates is at a different angle to the bore of the tube.
Sibbo
Re: LED spot light.
Post by Sibbo »
I'm not quite sure of the job you describe but my 5" angle grinder gives a good enough fit for brazing. The elliptical cuts are just bevelled to give a close fit , probably 1/32" .
The Grateful Dead
Re: LED spot light.
Works of art Sibbo!
PITApan, when quoting try and edit out the photo link. We don't need to see the pics again, and I'm on my 5th set of mouse wheel bearings.
Re: LED spot light.
PITA, I think his are constant radius arcs (semi-circles), so they're really easy to mark tracing with the end of a tube. Then he apparently just ground them out. To get the arcs it sounds like you need, the only way I know how to do it is to cut section of the tubing at the same angle the plate will meet the tube and trace from that to give you the correct ellipse. If you don't have extra of the tubing you're welding to, and can't find some scrap of the same OD, I don't know how you do it, unless you have a 3D CAD program to generate the correct curve.
Sibbo
Re: LED spot light.
Post by Sibbo »
Or maybe a narrow strip of lead, say 1/8" x 1/8"... that holds a shape quite nicely. So do those hardware store gadgets with the movable pins, kind of combs with sliding teeth. They'll pick up a shape beautifully .
MS's way is best if you have the extra material.
The Grateful Dead
Re: LED spot light.
Lovely bit of work there, Sibbo.
I am also keen to see the result of road trials.
PITAPan
Re: LED spot light.
Post by PITAPan »
Sibbo wrote:Or maybe a narrow strip of lead, say 1/8" x 1/8"... that holds a shape quite nicely. So do those hardware store gadgets with the movable pins, kind of combs with sliding teeth. They'll pick up a shape beautifully .
I can draw the layout (development) of the curve on a drafting board, old school, or do it on CAD.
I've got the nice version of the sliding pins thing (sliding blades), lead filled drafting curves, sliding spline adjustable curves (another drafting tool), etc, etc. And then there is taking a bondo casting and running it at an angle on the sanding disk, etc. I can pretty much capture anything. (I do industrial modelmaking)
It's cutting the thing...The mirror mount is right in your face, it has to be tight and the plan is to braze. I can give the grinder a try. I just hate free handing stuff and Santa ain't brought me a mill yet. Need a bigger chimney.
PITAPan
Re: LED spot light.
Post by PITAPan »
ME 109 wrote:Works of art Sibbo!
Ah. Gotcha.
This explains four thousand eight hundred and sixty four pics of the kangaroo. :shock:
Re: LED spot light.
Ah. Gotcha.
The roo has only been there for a couple thousand posts.
And he's only a little tacker and doesn't make my posts any bigger.
But he does drink all my beer!
Re: LED spot light.
I And then there is taking a bondo casting and running it at an angle on the sanding disk, etc.
Oh, I like that idea.
