1979 r65 battery
Re: 1979 r65 battery
Wobbly wrote: Thu Aug 10, 2017 8:19 am .... I'm simply wondering if your reading and the table numbers are simple voltmeter readings or those made with a battery load tester.
Simple volt meter readings on a rested battery.
Wayne J in MA
Post by Wayne J in MA »
Zombie Master wrote: Thu Aug 10, 2017 3:38 am I use one of these http:/http://saskbattery.com/ecommerce_183.htm
It needed some shimming to fit snugly. Very strong!
Same as I use. The first one lasted 10 years. Finally killed it by leaving it in the cold bike all winter with no trickle charge.
I used to call on the East Penn DEKA plant. It is huge and many of the batteries for other brands are made there. I could always count 10-20 other brands in process.
Wayne
Wayne
1978 R100S Motorsport
1971 R75/5 SWB
1962 R69S
I've been using the Deka for quite a while too. Excellent battery.
Roy Gavin
Post by Roy Gavin »
Reading Odsyessy's charger information minimum output for airhead sized batteries is 6 AH so almost every charger sold for motorcycle use isnt going to cut it!
