Handlebar Master Cylinder Conversion
Re: Handlebar Master Cylinder Conversion
sterob wrote:I'm in the throws of fitting a second caliper and disc to my 77 R100/7. The single disc, even with a Handlebar mounted M/C was not good.
I'm using two 40mm piston calipers and a 14mm handlebar mounted M/C from Motobins.
Glad you posted. I'm getting closer to doing the dual disc conversion on my '76 R75/6. I already have that all important R/H slider, calipers, and most of the necessaries. I had forgotten that Motobins sells a turn key M/C kit (at least I think they sell everything for a kit).
A few years ago I converted my '77 R100/7 to dual disks, albeit with the under tank M/C. Still and all I was pleased with the conversion. I will like the handlebar mounted M/C much better.
Who knows, I just might order two handlebar M/Cs and make both bikes brake better.
Ken in Oklahoma wrote: Glad you posted. I'm getting closer to doing the dual disc conversion on my '76 R75/6. I already have that all important R/H slider, calipers, and most of the necessaries. I had forgotten that Motobins sells a turn key M/C kit (at least I think they sell everything for a kit).
Put both of them on the '76. The brakes will turn out twice as good.
sterob
Post by sterob »
jagarra wrote:A good way to burp the final air from the system is to pump up the handle until you get a really firm resistance and lash the handle to the handlebar to keep the pressure on overnight. Seems to get the last of the bubbles out.
gg
Thanks Jagarra. I'll give that a go and see how it goes. If it improves, I'll know I didn't get it all.
It seems ok now, so will see.....
Don't forget that Charlie aka Airbear has done the handlebar conversion on his 90/6 using Magura parts with heavy cost saving and excellent success. He's posted in here about it before.
SteveD wrote:Don't forget that Charlie aka Airbear has done the handlebar conversion on his 90/6 using Magura parts with heavy cost saving and excellent success. He's posted in here about it before.
Indeed, I have been paying attention. The difficulty for me (for example) is that my '76 R75/6 has different switchgear than Airbear has. His is an early /6 with the /5 style switchgear. Simply, my later switchgear leaves not enough room for the master cylinder. I believe Airbear also had to add an extension to his handlebar ends to get the master cylinder away from the bend in the handlebars.
If I remember correctly, the later master cylinder that I plan to use also requires certain pieces of the throttle mechanism, mostly because BMW changed the design from what they used to have and what is now needed. As you can probably tell I'm fuzzy on the details. When I go to actually do the conversion, next summer, I will have sharpened up. But I seem to remember that Motobins has this stuff figured out and the problems are handled with their "kit". I think there's another seller who also has a kit, but I can't remember the name.
zeroweaver
Post by zeroweaver »
I am looking to do the same but I have a dual throttle and a 14mm piston oem MC. I need a 14mm Magura MC. And also will this fit my dual cable setup??
1975 R75/6 custom - In Progress
moosehead
Post by moosehead »
Norm T R100T R1150RT wrote:Can a "single throttle cable" controller be converted to a "dual" cable ? I've been considering the swap from "under the tank" to bar mounted and have the dual cable set up currently. Hoping that with a combination of parts I can accomplish this conversion. Thanks, Norm
Yes...just use the same set up as on the 81 to84 models e.g. RS and RT that utilize a single cable upper to a splitter for dual cables to the carbs? Or maybe I'm missing something?
You would need the upper single throttle cable, splitter, and the 2 lower throttle cables.
Later monolever models reverted to dual throttle cable setup from the handlebar to the carb I think. No cable splitter. Sourcing parts from those shouldn't be too hard. The handlebar chain and pulley mechanism with throttle grip is only available in a later oem version these days.
I'm not a fan of the cable splitter. I see it as just one more (unnecessary) device to go wrong. And they do go wrong. At least mine did.
